vokera compact 28 lockout
31 Oct 2006
Cheshire
hi
could anyone please help me?
i have a vokera compact 28 about 18months old. last few weeks it has been locking out when heating and hot water were on together. watching it, it was locking out after it was trying to ignite after it had gone out on thermostat.
but now it also goes out on hot water. first couple of times it works fine then turn the tap on again and it locks out.
fan appears to work fine.
pressure also seems fine.
any help would be gratefully recieved
many thanks in advance
MARK
Hi there. Your Vokera is 18 months old so is covered by Vokeras warranty. Get the A holes who Designed and made it to fix it
Vokera compact is more likely to be 3-5 years old common easy fix fault is to replace thermister
Nortimax, is you post a rant or is it something I do not know?
hi
thanks for advice but i got the boiler thru a contracting firm i work close with, and they kept the receipt for vat purposes. they now cant be bothered to trace it.
i have engineer coming today from vokera @£175. sometime between 8.30am and 5.00pm. i wll post his findings if anyone is interested.
thanks again
mark
hi
thanks again
mark
Boiler comes with a 2 yr gtee you don;t need a receipt only a serial number to confirm which is on the underside of the boiler.
Boiler should have been notified anyway so there should be paperwork somewhere regarding when it was installed.
