How do I wire a replacement 2 way 2 gang light switch
7 Sep 2007
Leeds
The old one has a single'block' on the back with 3 terminals top and bottom L1 L2 and com.
New one has two 'blocks' with an L terminal at the top of each and L1 and L2 at the bottom of each.
There are 4 incoming cables, 2 have a red and a black wire and the other 2 have a red and a green.
How should I wire the new one please
Any help gratefully received.
Do they actually read
L1 L2 COM
COM L1 L2
If they do, can't you see which COM is associated with which L1 & L2?
If not, and if you can't tell from the wiring which must go with which then you'll have to use your multimeter to find which goes with which.
Red and green?
That's a strange combination - are you sure?
And no earths? I hope your new switch isn't a metal one...
Assuming it works how it should, the same as the old one - just transfer the wires from their existing COM/L1/L2 terminals to the corresponding ones on the new switch.
http://www.diynot.com/wiki/electrics:lighting
My apologies - yes, it is. The various alternative identification systems are (these won't line up perfectly, but hopefully you'll get the drift):
  • COM L1 L2
  • L1 L2 L3
  • L L1 L2
