honeywell cm zone reliable ?
2 Oct 2004
hello
honeywell cm67z and hr80uk will they work togther or
more hardware needs to be added ?
TIA
There is a new controller for CM zone based on the CM series shell.
We don't fit them (we do the larger Hometronic system) but the HR80s etc are very reliable in service.
You have not described the application so I can't tell you if it will do the job; but if you buy the CM Zone pack then it incorporates a boiler controller and a set of rad heads. If you want to control your heating then yes, everything is included, apart from possibly the actual VH200 valves, I don't know if Hwell package these in the kit.
Hello simond
Which new controller ?
Any links to Hometronic website and prices ?
Need to control 2 trvs and use trvs as a zone valves/controls to turn off radiators when rooms unoccupied (8-12 hours). The controller needs to be wall mounted at shoulder level be easy to read/adjust and have digital room temp displayed ( shoulder level and digital minium).
The kits found have 6 hr80uks and are £500 only 2 trv heads needed + 2 VH200 valves + controller . More to be added as needed.
simond and more help suggestions ?
TIA
You will find the info on CMZone at
http://www.honeywelluk.com/product.aspx?r=ws&p=2398
Links to Hometronic are on that page or my web site has details - there is an installation blog featuring actual installs (see my profile). Hometronic is CM Zone's big brother and is not a DIY product, cost is around £3-4K.
It would seem the new CM controller has not come out yet, but it will be changed to the units similar to CMT 927 etc, I am told. Currently the CM67z is using the design of the 2005 range.
If you are eventually going to fit more than 6 heads you would be better looking at Hometronic, this gives massive savings and individual room control of up to 16 zones for the cost of a cheap solar install. Solar being a white elephant that never pays back.
