My immersion heater is attached to a fused switched outlet. The fuse cover is getting hot when the immersion heater is switched on. Is this normal (bearing in mind the load going through it) or does it indicate a fault? I've replaced the fused switched outlet and the wiring between outlet and immersion (it had 4mm cable so I've replaced it with 4mm) and still have same problem. Could there be a fault on the immersion thermostat and the heat is travelling back along the live cable to the fuse?
