- Joined
- 11 Dec 2004
- Messages
- 1
- Reaction score
- 0
- Country
Hi All,
I've got some trouble with my immersion heater and I'm hoping someone on here can save me the expense of getting in a tradesman to fix it as I believe that there is something simple wrong with it.
The problem is that the immersion heater is blowing fuses at the consumer unit continuously - as soon as the fuse is inserted and the switch is pressed, it blows - I can see the flash of the fuse blowing.
I have the immersion switch turned off when I insert the fuse. All is well until the immersion is turned on and it is then that the fuse blows.
The fuse being used is a 15A cartridge type - it is a direct replacement for what was in previuosly.
I have checked the 13A fuse at the actual heater and it seems fine. There have been no modifications or upheaval around the circuit which could have caused this problem.
Does anyone have an idea as to what could be causing the problem. At a guess I would say that the circuit is trying to pull (sink?) more current than the fuse will allow (15A) and therefore the fuse blows. But why is this happening now?
Any ideas?
Cheers.
Willy.
Any ideas?
Cheers.
Willy.
