Boiler wont fire up and getting the flashing L F code. Seems a coincidence that it started playing up after draining the hot water system to change some taps. Not sure if or why this would affect the boiler.
One thing to note is that the central heating pump is constantly running, unless i turn the power of to the whole system or slide the switches on the control panel to off position on both the hot water and heating (dont think that right somehow)
Now, firstly the things i've tried and tested for.
1. opened up drain plug on bottom of sump to check for any air in system (none)
2. Checked the ignition electrode for continuity, wasn't happy with it (but that might of been my tester playing up) so replaced it with new one.
3. Checked voltage to gas valve. When the boiler goes through its start up process i get around 200 volts for about a second then goes to to 0 volts. As per the manuals trouble shooting it says change the gas valve. New gas valve fitted (still nothing)
4. Read somewhere to disconnected the live feed at L2 terminal on mains wiring coming into boiler to check if its the boiler or an external fault. If the boiler powers up and gives the reading '0' then its an external fault (so they say). Well boiler powers up and reads '0' on the display.
5. Checked to see if i get a spark at the ignition electrode by disconnecting it from burner and earthing, then covering hole to stop gas escaping. Get no spark or a voltage reading at terminal. Not sure if this is normal if there is a fault elsewhere or its a fault with the PCB!!!
Would appreciate any input before i start spending anymore money (which i haven't got at mo)
Cheers
Cheers
