my upstairs rads where not warming up i have flushed out rads but there now appears no preasure to push out air. i have a thorn m boiler should there be a valve to increase water presure or does it just work from water pump
valves are twist to open/close could be 30 years old there are hot and cold water tanks upstairsremoved rads took the outside and flushed the through with a hose pipe the boiler is old not like a combi water pump apears to be working as down stairs rads are hot
yes valves back on, very little aie coming out when try to bleed turned of valves when removed radsKeep it simple at first.
Have you turned the rad valves back on?
Is any air comming out when you bleed the rads?
Did you just turn the rad valves off when you took the rads off, or did you isolate the tanks?
Andy.
Andy.
if i loosen valve from pipe work water should rush out if not blockage in system system is 10mm flexi pipe whats best way to flush out whole system.
norman
