The boiler went cold although powered & the CH pump was running, front panel stat set to 90 degrees.
I determined that the front panel thermostat was not working [ power into but not out of ] and assumed that is the problem.
As it was cold and lodgers begging for hot water, I bypassed the front thermostat and the burner ran. All seemed ok but I wasn't just going to leave it, a 10 minute burst to warm it up then maybe 5 minute bursts every 10 mins or so until the HW cylinder was hot.
However, I heard air rushing through pipes to the header in the loft [ an interesting noise ] so assumed the water in the boiler was super-heating to steam.
I then discover that though the CH pump is scorching hot and humming as though it is running, it's not pumping though.
I Bled the pump [ no air - just a few drips of black water ], bashed it a bit & it seems to run ok now.
The Thermostat seemed to start behaving [ set it to 85 ] by switching on and then off, but stayed off - after some fiddling up and down the temperature scale & switching on and off at the mains [ no real reasoning here ] it switched on and had behaved since.
Opinion please....
Is my initial diagnosis that the thermostat is broken probably true? & I should now replace it as a preventative measure?
Did I let it overheat the boiler water letting it run without thermostat and that overheated water siezed the pump? So the pump is probably ok - or should I be prepared to swap that out too?
Is black water from bleeding the pump [ only got a little water, is it supposed to 'flow' when bleeding? ] a sign it's gunged up?
Or any other thoughts?
What's a good temperature to set this thing anyway? 85?
Opinion please....
