potterton profile fan runs but dont fire
30 Dec 2008
Surrey
profile 50e fan runs boiler will not fire fan just keeps runing
help thanks
you could link it out but you can also check switch electrically without power on using multimeter. Check if you are getting continuity between common and normally open when you make switch by sucking and pinching
is the fan running constantly or does it keep stoping and starting
ok thanks i will test the aps if its working ok what else could it be
you can check for 240v on the pcb t4 orange from the aps and t2 is the black from the gas valve.
if yes pcb fault if no aps fault.
If the old fan ran constantly then a new fan would run constantly too.
Something else much have been done to correct the fault.
Tony
Tony
its funny you say that it worked all day now its doing the same thing again. Think the old fan was runing a bit slow as it fired when i sucked on the pipes on the aps. S0 i will fit a new aps next see if that works it also fires up if i pull the clear hose off the aps any ideas.
