Long post here – sorry – first time on here
My house is always finding new ways of breaking itself (circa 1900 terrace – not a lot done since then I think….lmao) It has a central heating system in it which I suspect is about 30 years old, supplemented by a boiler which was replaced about seventeen years ago. It is an Ideal Classic – vented indirect system with hot water cylinder, radiators upstairs and downstairs, cold water tank in roof, along with the expansion tank.
Now, from what I have read on this amazing site, I can only deduce that the coil in my hot water cylinder has a leak….. Expansion tank overflowing out of pipe which comes out of roof wall and drips onto footpath now constantly dripping and council now been complained to – its been going about three years apparently, one under my ownership…. I have tried various tests to ensure it is this
– ballcock into expansion tank is working just fine 1
– tied up ball cock, removed about seven litres of water (to about a third full from 5/6th where it usually sits overflowing) turned central heating/hot water on at 5pm and water comes through expansion pipe at a rate I would describe as a slow tap (ie trickling). The tank filled to halfway by 10.30pm when the boiler went off for the night. I made sure it didn’t come back on by turning it off at the timer, and by the next morning the expansion tank was overflowing again, and hasn’t stopped since. 2
I surmised this means that water is coming into the central heating system somewhere which has led me to the coil in the cylinder – if this has a crack/hole in it then the pressure from the cold water tank in the roof coming into the tank will push more water than necessary into the central heating system via the hole in the coil, and therefore into the expansion tank. 3
I hope you’re with me so far and this is making sense – I’ve numbered it all so you can reply and say I’m wrong about any particular bit.
So, I need to change the hot water cylinder right? 4
Now, I get how you drain cold water tank in roof (no gate valves or anything so luxurious on this system….) – turn off mains water supply, turn on taps, empty tank no pressure from above. 5
This is where I get a little hazy – if I empty hot water cylinder, will water from the central heating system not then fill/not allow me to empty to cylinder as it comes through the cracked coil? If this is the case I presumably need to drain the central heating system via the radiator with a drain-cock on it downstairs. If I turn the radiators off at both ends this will save having to refill them – question is though – how do I know I have reached a level in the system which would ensure the coil is totally empty so it does cover my bedroom with horrible dirty water when I take the inlet/outlet pipes off? Presumably wait until the expansion tank is totally empty, and then go quite a lot further? 6
Or could the central heating be on a separate loop to the coil and thus just require this loop draining? 7
From here, I have to drain the tank itself – some numpty has put in the cylinder so close to the skirting board that you could not hope to get a hose over the end of the drain cock– its almost like over the years the drain cock has settled into the skirting board. Do copper pipes have enough bend in them to risk moving the tank across 10mm 8 to get a hose pipe onto this drain cock or do I have to siphon it out of the top hole (hot water out) 9 and how do I ensure this hot water out pipe is totally empty 10 (same dirty water/carpet issues)
Now, assuming I can get this tank out, the real questions begin –
Are tanks made to standard specifications (ie will the holes be the same distance apart on a new equivalent sized tank) or is there a chance I will have to modify pipework? 11 As I have no experience of this. Cylinder is covered in yellow insulation – think I read somewhere this would tell you roughly how old it was (?) It is the type of foam that came already attached with the cylinder from new and is more like smooth finished dense polystyrene, not roof lagging stuff. 12
Now assuming I have this new cylinder sitting there plumbed in, all tightened with PFTE tape at the joints – how do I know the thing won’t leak when I fill it with water, as it wouldn’t take much to ruin the bedroom and the ceiling below – or is it fill it and keep your fingers crossed? 13
And any tips for refilling to avoid airlocks? Both cold water system and central heating system.
Am guessing (again!) that with the cold water system – as per reading on different threads on here and putting them together – open all cold and hot water taps and then turn mains back on. Hope for best. 14
On hot water system, allow expansion tank to refill after finished refilling mains system and cold water storage tank. This will presumably create some airlocks in the system which you would then effectively let into the closed radiators and bleed out in the normal way you would bleed a radiator. 15
I really do appreciate your time and knowledge in this – I would normally get a plumber in to help with something I was not sure of, but unfortunately I have just been laid off and do not have the money…. Great Xmas present – thanks work!! So I have plenty of time to devote to this (and finding new employment!) but not a great level of knowledge – time to improve the knowledge bit I think – thanks in advance!!
