Hi. My boiler has developed a problem. To start and stop the boiler when needed I usually use the left of the 4 grey buttons on the front. For some reason it is no longer firing up. I don't think the fan is even coming on. The boiler will not even fire uo to heat the water. I did however manage to get it working 3 days ago and if you leave it alone it is fine (hot water and heating - ignites and goes out as it should). Last night I switched it off with the grey button but now it won't ignite again. Dial on front showing 1.5 bar and green light on front flashes quickly when I press the grey button. Also there is a red light inside the boiler when the hot water tap is on. It just will not start it's first initial fire up now. Any ideas please.
