I have undone and removed the large screw on the front off the pump. I have pressed the button to start the boiler and can tell that the pump is spinning as it should until the clicking and whiring stops and the pump stops as well.
There is nothing wrong with the diverter valve as far as I know.
There is a problem with the primary flow. Just increase the system pressure a little in case the gauge is jammed.
