Water pressure on boiler dropping really fast
11 Jan 2009
Hi there,
Newby DIY semi-incompetent please be gentle :)
I've looked elsewhere here but I can't find an answer to this exact problem. I noticed the pressure on our Wiessmann boiler was at 0.5 bar this afternoon, I refilled it to 1.2 bar, within 20 seconds it was back down to 0.5.
The central heating isn't switched on but it must be a leak somewhere I thought but I couldn't find anything anywhere including coming out of the pipe exiting the house. For it to drop that quickly I would have thought it must be a fairly major leak (if that's what it is!)
2 questions:
a) Is it dangerous to have the prssure at 0.5
b) Could it be anything else other than a leak
cheers !
The strange thing is, is why it apparently stops leaking at 0.5 Bar :?
If there was a major 'normal' leak, I would expect it to drain to zero each time.
I assume the pressure gauge is not faulty and sticking a 0.5 Bar?
Makes me think that if it's a leak, it may be around five metres above the boiler :?:
This is probably a stupid question but if the central heating isn't switched on could the leak still be coming from a radiator / pipe associated with a radiator.....
Pressure still stuck at 0.5 and the hot water pressure out of the taps seems normal (whether that has anything to do with it)
what did I tell you - incompetent !
However, I realised there were some central heaitng pipes in the attic, actually about 7 metres above the boiler and there appears to be a large puddle of water under one of the joints - I think I may have found the problem....now I just need to find a plumber to come and fix it
Anyone live near Limoges in central France ??
PS I'm assuming it's safe to have showers / run dishwashers etc with the pressure that low ??
Thanks everyone for your help - I have a feeling I shall be back here. If anyone needs PC advice in return.......
I shall assume it is safe to have a shower and the house is not going to blow up.
I would assume the the boiler has a safety cut out for low pressure, probably around 0.3 Bar. So using HW should pose no immediate problem :wink:
