- Joined
- 12 Jan 2009
- Messages
- 6
- Reaction score
- 0
- Country
Our central heating uses the Honeywell Y plan and I am trying work out the purpose of a piece of pipework and a stop valve.
On the main circuit downstream from the circulation pump and upstream from the mid position valve there is a 15mm pipe tee'd off from the 22mm main pipe. This pipe has a hand operated stop valve on it and is then tee'd into the outlet (cool side) of the hot water tank heating circuit.
What is the purpose of the circuit and should the valve be open or closed normally?
P.S. The system was probably installed in the early 1990's and has an oil fired Worcester Danesmoor boiler if that makes any difference.
