    Dismiss Notice
honeywell y plan valve
Discussion in 'Plumbing and Central Heating' started by colincop, 7 Oct 2008.
  1. colincop
    colincop
    14 Aug 2008
    32
    Thanks Received:
    Southampton
    Country:
    hello can anybody advise me i have just replaced the honeywell y plan
    motorised valve onto the main brass valve . but in order to put the the
    heating on i have to push the spring loaded lever to the left manualy
    then the heating will fire up . once i turn it off and command hot water
    only i can see the spring move to the central posistion which is fine
    but it wont go back to the heating when i call for it
    any ideas regards colin
  2. Softus
    Softus
    21 Oct 2004
    19,558
    Thanks Received:
    12
    Country:
    1. What was the original symptom that you were attempting to fix?
    2. What does the following mean:
  3. Sponsored Links
  4. colincop
    colincop
    14 Aug 2008
    32
    Thanks Received:
    Southampton
    Country:
    the electrical part had broken so i replaced it
  5. Softus
    Softus
    21 Oct 2004
    19,558
    Thanks Received:
    12
    Country:
    That's not a description of a symptom.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
