When my central heating (but not hot water) is turned on there is a brief ignition of approximately 30 seconds before the ignition stops and an error message of S.53 appears, that is (according to the manual), 'appliance is within the waiting period of the operation block function due to water shortage (VL - RL spread too big)'. The boiler can remain in this state for up to 30 minutes before it successfully ignites and appears to work.
This problem occurs whether (a) the central heating has been off for some hours, typically overnight, or (b) when the central heating has been off for some minutes, typically when the living room has reached the temperature dictated by the room thermostat and the room temperature has then dropped and so the boiler tries to get going again.
The problem does not occur when the hot water is turned on immediately prior to the central heating being turned on.
So far I've had (a) new pump fitted and (b) new heat exchanger fitted. But problem continues.
Any help/ advice gratefully received.
