I had my new boiler installed which was completed on Tuesday. It is a Worcester 440Cdi (combi) and installed in the loft.
There is bathroom adjacent to the boiler (same level). There is another bathroom directly below. The kitchen is directly below the bathroom. So they are all in the same part of the house but on different floors.
In the kitchen, I only get hot water out of the tap if I turn the tap all the way on. When I had the boiler in the kitchen, I could turn the tap just a little bit and I got hot water. The bathroom is fine, I get hot water if I turn the tap half way.
Is this a pressure adjustment which can be fixed for the kitchen or is it because the boiler is now further away?
Yesterday I also tested out two showers at once. I turned both showers with the hot tap on full and did not use the cold. The pressure was fine. The water was luke warm. Is this because the boiler cannot cope with the hot water demand? I would have thought that the pressure would drop when both are on, not the water temperature?
Before I call the plumber back, can anyone help with the two issues if they are "faults" or "working as designed"?
