Hi people,
My 10.8kW shower popped its themal cut-out, frying the closest 30mm of the main power cable attached to it, before the thing refused to play. Getting a new cut-out was easy but I've never seen any cable before like the one that was installed but is now damaged.
It has '4mm silicone engineering' printed on the soft silicone feel sheathing. The conductor is 56 strand silver colour (as apposed to copper). Cross-section looks about the same as 6mm2.
Length is 250mm running inside the plastic shower casing. It is very flexible. No-one I have found knows of it or has sensible suggestions of what I can use instead. I could bend a length from a section of 6mm 2 or 10mm 2 so it wouldfit perfectly but would std PVC insulation be ok???
Any ideas please?
Bmused!....................
Any ideas please?
