Hi, im new to the site and im looking for some advice. My situation is below, sorry for the length of it.
I have a 1940's semi detached house in Lancs.
The property has a hipped roof, with concrete tiles (i think). There is no felt lining and you can see daylight through some of the tiles when you are in the loft.
My problems are:
The house is ALWAYS cold, the walls are freezing and condensation is a massive problem. The bedroom and bathroom have the most condensation and subsequently mold has appeared on the ceiling and the walls.
The bedroom is of major concern as the walls have been wet to touch at times. I applied for cavity wall and loft insulation through a government site and the surveyor has come and inspected the property. He confirmed the house has no cavity wall insulation (even though my homebuyer survey said there was evidence of foam insulation) and the loft insulation was 25mm (apparently it should be 11inches?). He thought that as the walls were that wet i.e. water has run down the walls and left water marks all over, that this was not JUST condendsation but actual rain water coming in.
I was advised by the surveyor that he could not put loft insulation in as the bedroom ceiling was cracked and looked weak and apparently couldnt take the weight..., and he cannot do the cavity wall because the bedroom walls are wet and the cause needs to be rectified first.
I have had two roofers inspect the house and they both confirm the roof is rubbish and has to be completely renewed.
1. Quoted me £2.5k (excl scaffolding) for a new tile roof
2. Quoted £4k - £4.5k for new roof (tiles and dry ridge tiles), gutters, facias etc (includes scaffolding)
The second quote to me sounds a better one for me, as he has included everything I need, plus I get a good 'vibe' from the firm.
My questions are:
1. does circa £4k sound right for a 2 bedroom semi (hipped roof) plus guttering etc?
2. is the surveyor right that I need to sort out the causes of the problems before having the insulation fitted? I agree I need a new ceiling, and thats not a problem for me, but im worried that I might get a new roof/guttering and cavity wall insulation and the problem still be there.
Many thanks for any advice
Kindest regards
My problems are:
My questions are:
Kindest regards
