Lifestyle trvs, temp settings please
21 May 2008
Shropshire
Hi, upstairs rads have been turned down to 2, as rooms getting to hot, even set at 2, rads are still on, room temps at mo about 20/21, does anyone know what the temps are set to on these, thanks
No data available on the Lifestyle TRV - must be fairly old. Most TRVs will give a temperature about 12-14C when set to 2.
Do you keep the bedroom doors open? If so, heat will rise from downstairs and warm the rooms, even if the TRV has closed the radiator.
Do the rads upstairs feel hot all the time? If so, the sensor in the head of the TRV may have given up.
Lifestyle are now Drayton. All current Drayton TRVs use the same body, it's just the head which is different. So you may be able to get new heads for your valves. Check with Drayton:
Customer Service: 0845 130 5522
Tech Helpline: 0845 130 7722
Email: [email protected]
