I have a three gang switch in my hall way. The switches are for the landing light, the hall light and the porch light. The landing light and hall light both work, but the porch light doesn't.
I turned of the electricity and opened the cover of the porch light, assuming the bulb had gone - to find the light wasn't wired up. (It's never worked in the time I've lived here.)
There are two red (live) wires, which are connected together. There are two black (neutral) wires which are separate. There is no earth wire, so I have replaced the light with a new one from B&Q that does not require an earth, just to be on the safe side.
If I separate the red wires, the landing light and hall light don't work. If I connect the black wires, the trip switch goes as soon as I put the electricity back on. So I know the two red need to stay connected and the two black ones need to stay separate.
If I wire the light up to both red wires in the live connection and one black wire in the neutral connection either the light doesn't work at all or it is permanently one, no matter what position the light switch is in.
DOES THIS MEAN THE SWITCH IS WIRED INCORRECTLY?
If it does, will buying a new three gang switch (for the instruction leaflet that comes with it!) to rewire it solve my problem? Or is it a more serious problem that requires an electrician?
(I've rewired a new security light and changed standard two gang switches for dimmer switches, so I'm competent with the basics.)
