Plasterboard Gaps
  • Thread starter Thread starter an
  • Start date Start date
an
1 Mar 2009
Northamptonshire
I have recently modified a utility room by replacing the existing 90 degree corner to one which is at 45 degrees. I re-built the stud frame and applied new plasterboard on the new studwork. When applying the plasterboard I noticed it does not join exactly to the original and I have gaps of about 3mm. Is this something the plasterer will be able to overcome or should i try to fill the gaps with something.
an
skrim tape the joints and the plaster will take care of the rest no probs!.
If i may butt in here, alastair, i have much bigger gaps in my wall where odd un-straight lines don't meet. Sometimes over 10mm. What i've done is either filled them with board adhesive as i've stuck them down, or filled them later with a silicon filler then scrimmed over them.
Is this ok too?
Is this ok too?
thats fine kjacko long as you remember to use skrim tape at all the seams.
The boards should be butted together; if you have gaps it won't matter but fill them first. If you don’t fill before taping you may well end up with a tell tale ridge in the finished skim along the line of the join; this is caused by the skim failing to penetrate sufficiently through the mesh tape into the void behind; it also makes the plaster over the join weaker & more liable to crack.
Is this ok too?
Board adhesive is OK but I wouldn’t use silicone, nothing much sticks to it. I just rough fill with a little Multi or if the gaps are larger, Bonding & then reinforcing tape; but maybe wasteful to buy a whole bag Bonding just to fill a few gaps.
