Hi All
I've got a question which I'm hoping someone can answer -
So I've got a Victorian semi, the previous owner had two Vaillant combi boilers installed, one supplies hot water to the ground floor, one to the first floor - heating the same way (why they went for two and not one large one I do not know).
My question is with regards to the hot water supply. Is it possible to combine the hot water outputs of the two boilers, supplying the whole house from the pair rather than each floor individually? Would this give a better hot water flow rate or ultimately just consume more gas (with no real increase in flow)? Water pressure is relatively high, at the moment the hot water flow rate is nowhere near the cold water rate. Shower flow is fine, just takes ages to fill the bath.
Cheers
Cheers
