HW and CH fault
8 Apr 2009
Surrey
very frustrated. HW + CH fault. using honeywell motorised valves and room thermostat. Programmer and boiler all of which are tested and working perfectly individually but not coordinating. experienced qualified plumber and CH installer unable to locate problem and any suggestions very welcome. wiring also checked
carlolionel
carlolionel
Whilst I cannot guess even what the actual problem is from what you have said, it does seem obvious that the plumber is not very clever as he cannot identify a simple fault with your system.
Would you want to fly in a 737 plane with someone like that responsible for maintaining and fault finding on it?
Tony
thanks - however I have dealt witrh the guy for over 25 years and jhe's first class. Present suggestion is loose scale inthe pipework interwefring with valves
It would help immensely if you actually stated what the fault was :?
As said before, what system is it etc?
Most of us are probably second class so how do you expect us to be able to find the fault without even visiting you as he has done?
In reality if he cannot find a fault on a simple system then I reckon he is Third Class or worse!
Tony
