Had my system power flushed about 2 months ago and everything was working well. Recently the downstairs rads stopped getting as warm as before, then after another week they are now stone cold. All upstairs rads were working as normal. Now only 2 out of 4 upstairs rads are still warm.
All rads have been bled (no air found), and I have checked the pump by removing the centre screw which seems to be running (also a little water ran out so no trapped air).
Watching the 6 red led lights on the boiler (30 deg to 80 deg) I can see that it heats up from 30 to 80 in about 30 seconds at which point the flames go out. It then takes about 5 minutes to cool to 30 deg before firing up again. So I basically get about 30 seconds of heat every 5 to 6 mins.
Not sure where to look now, but :-
1.) Should the boiler wait until it cools to 30 deg before firing up again. I am sure it didn't do this before.
2.) Is it possible for the pump to be failing and not pumping water round the system fast enough. Boiler is 12 years old and its never had a new pump.
Thanks in advance
Thanks in advance
