I have an old Sangamo 410 (F4) programmer that is worn out. I bought a Salus EP200 (Digital 2 Channel) programmer, but just cannot get the boiler to work with it.
The old Sangamo has 8 connections on its backplate as follows:-
1 - Connected to ?(A) also Bridged to 6
2 - not used
3 - Mains - Live
4 - Mains - Neutral, also connected to ?(B)
5 - Connected to ?(A)
6 - Bridged to 1
7 - not used
8 - Connected to ?(B)
The system is gravity fed but with a pump on the oil boiler and a single room thermostat.
The wiring diagram says the connections are as follows:-
1 - ? switched to a Neon and switched to a motor?
2 - not used
3 - Live input & to a motor?
4 - Neutral input & to a motor?
5 - bridged to and connected to the Neon?
6 - switched to HW(7) or CH+HW(8)
7 - connected to HW via switch to 6
8 - connected to CH & HW via switch to 6
I assume 6,7, & 8 is just the switch from HW only to HW+CH
So now I come to the Salus programmer, which has 6 connections on its backplate as follows:-
N - Neutral
L - Live
1 - HW off
2 - CH off
3 - HW on
4 - CH on
I have tried the following old to new
1 to 1
3 to Live
4 to Neutral and
4 to 2
5 to 3
8 to 2
I have also tried the following old to new
1 to 3
3 to Live
4 to Neutral and
4 to 4
5 to 1
8 to 2
In neither case does the boiler respond, even though the Salus indicates either that the CH is on, the HW is on or even that they are both on.
Any ideas - the water is getting cold, and I am getting fed up re-connecting the old Sangomo just to operate it manually.
JR
2 - not used
3 - Mains - Live
6 - Bridged to 1
7 - not used
2 - not used
N - Neutral
L - Live
1 - HW off
2 - CH off
3 - HW on
4 - CH on
1 to 1
3 to Live
4 to Neutral and
4 to 2
5 to 3
8 to 2
1 to 3
3 to Live
4 to Neutral and
4 to 4
5 to 1
8 to 2
JR
