My heating and hot water is on a old sundial plan (does that make it an S plan?). I've already swapped the ST1000 programmer for a ST6400C without any problem. Now because the 'stat is about 2 foot away from the hot water tank I was planning on swapping it for a wireless version, the HC60NG. Being naive I thought that it would be a straight wire for wire but that doesn't appear to be the case.
This is where I turn dumb. the old stat was marked up 1,2 and 3. and the new one, ignoring the permanent power feed is A,B and C. What goes where? Originally 1 connected to 4 (CH on?), 2 to 2 (Neutral) and 3 to 5 (White wire on the mid position valve). I can't see a diagram for connecting to the sundial wiring center.
Best guess at the moment is that A should go to 4 and B to 5 which leaves the neutral on 2 spare?
Any advice appreciated before my head explodes.
