Hi, can anyone advise what to do about this please, i know nowt about boilers:
My Mother recently had a visit from a guy from Scottish Power to check her gas boiler.. it's a Glow Worm Majorca fire/bbu in the chimney breast of the living room.
He told her that the boiler is not safe to use and gave her a warning/advice notice which does warn that the boiler is 'AT RISK' and should not be used as it 'requires ventilation' but it does not provide any advice as to how to achieve this .. so basically is it the space in which the boiler sits that needs this extra ventilation and if so can a vent be made to the void beneath the floorboards?
It is a terraced house so putting a hole straight through the outer wall isn't viable.
Finally, and just out of interest i know the boiler was professionally installed & the warning notice does state that it is gas tight, was installed with correct materials & fittings and correct pipework; it has worked problem free for many years so is there an honest reason why suddenly it is now unsafe to use it when nothing has been altered or changed?
The chimney flue is lined by the way.
