cant find a toilet
11 Apr 2009
need to find a toilet that will attach to a vertical waste outlet that is 29cm centre of the pipe from the back wall.
does anyone make such a thing , ?
No, but they make a flexible hose to suit regular toilet or 90 degree pan connector.
I hate flexi pan connectors. In my experience they are too prone to blockages, often because they are poorly supported, or used inappropriately
If you can't shift the pipe, then consider shifting the wall. It's often possible to build out the wall behind the pan with studwork, so the exiting pipe is nearer the finished wall.
Or use a back to wall pan with a concealed cistern.
I would try using a swan-neck connector, which I think is a better option than a flexi connector.
Did I mention I hate flexi pan connectors?
Ah, the true DIYers choice...hideous things.
It seems Tickly T has said everything I would, so I'll leave it at that...if you go for building out from the wall, consider doing it just behind the toilet, you don't have to do the whole wall (I know you weren't suggesting this TT, just clarifying...)
It`s a diyer`s forum, I could tell him to relocate his soil stack but I don`t think he would be up for that. :roll: Jesus, does every post on here have to be argued over. :roll:
He has a soil pipe sticking out of the floor. FFS. :roll:
Indeed it is, but we can still teach the DIYers to do things properly. Stack relocation would indeed be a little extreme. And I wasn't arguing, I was commenting. If you're going to be on here, you need to learn to accept other people's opinions without wanting to smash their teeth out...just relax a little
Not sure i understand correctly but a low level pan and cistern with a flush pipe allows you to fit the pan further away from the wall. The vertical waste can then have a 90 bent pan connector in to attach to the wc.
http://www.tradeplumbing.co.uk/Files/NoCodeArcade/No-Code-Arcade-Complete-Low-Level-WC.htm
The above link give a picture to what i mean and the flush pipe can be adjusted to suit. 29 cm is a good distance but im sure you could get a flush pipe to suit your needs.
i guess the only option is a concealed system and a back to the wall toilet, which is a shame as i need to box in the system to allow for the distance
