Err no it won't. It's a point were any movement in the floor will be shown by cracking tiles (silicone or no).
Would have thought that a nonails type adhesive would set rock solid over time. If not, then I stand corrected.Err no it won't. It's a point were any movement in the floor will be shown by cracking tiles (silicone or no).
mr dextrous
This is either an insult or a demonstration of deep respect. Can't work out which![]()
It will, but you'd still end up with weak points where it could flex.Would have thought that a nonails type adhesive would set rock solid over time. If not, then I stand corrected.Err no it won't. It's a point were any movement in the floor will be shown by cracking tiles (silicone or no).
Point well made and well taken.It will, but you'd still end up with weak points where it could flex.Would have thought that a nonails type adhesive would set rock solid over time. If not, then I stand corrected.Err no it won't. It's a point were any movement in the floor will be shown by cracking tiles (silicone or no).
No more ply.
so...... what is the best solution for my problem![]()
The whole point in replacing the floor with 25mm ply is to make it rigid. If you're talking about having a strip routed out so that it leaves the ply at a thickness of 3-5mm then I fear you're going to have problems with the ply flexing over this area. If I were doing this job, I'd be overboarding with 12mm ply and living with the extra floor height. At least this way you'll have piece of mind.
