C & M brittony boiler pressure switch?
19 Apr 2003
Durham
My boiler tells me the fan is running but the pressure switch has not operated. My question is, Should i be able to blow through BOTH the pipes that come out of the Flue? One marked H on pressure switch is open and can me blown through but the one marked L appears to be blocked within the flue? Is this an easy fix or am I missing something.
The switch doesn't appear to operate at all...?
Panic over... The venturi pipe was blocked. I took it out completly and cleared the blockage with a piece of stiff wire. Now all working again. :D
I am glad to hear that its all working now.
I would not have been able to give you any advice as thats a job which should only be done by a gas trained person!
Tony
Or a competant person? Poking an obstruction from a pipe is hardly " skilled" work?
Tony
What is the point of posters asking questions when the replies are not at all helpful? Surely not replying at all serves the same purpose? Or does it make you feel "superior" ?
