Yes, if any water was drawn off at the top of the cylinder. If the draw off point is lowered the pressure will increase at that point and so will flow, if the diameter of the outlet is constant.As far as this thread is concerned the top of the cylinder is virtually level with the bottom of the tank, therefore the head will be very very low.
The inlet head, is the distance from the storage tank to the bottom of the cylinder, that dictates the absolute maximum pressure and flow, you cannot get more out whatever you do.
Now consider cmother 1 example, where he raised the shower rose and the pressure dropped the higher it was, because he was reducing the head.
Before the water can go anywhere it has to go to the top of the cylinder, reducing the head by that distance, so at this point we have say 0.2 bar and 20Ltrs/min, happy, that's the maximum we are going to get out of the cylinder, running a pipe to the kitchen on the floor below, cannot increase the head or the flow, it is set be the height of the outlet. to do that I would need to take the cylinder down a floor.
Ok back to cmother 1 by the same token, the higher I take the out pipe from the cylinder the lower the pressure will be, (pressure/head being related)
Doitall you wrote:Yes, if any water was drawn off at the top of the cylinder. If the draw off point is lowered the pressure will increase at that point and so will flow, if the diameter of the outlet is constant.As far as this thread is concerned the top of the cylinder is virtually level with the bottom of the tank, therefore the head will be very very low.
I know this because I have a powerful shower in a my bathroom which is great and, surprisingly for your side of the argument, the hot water tank is in the loft (of all places) directly under the CW tank. Not more than 6 vertical inches between the top of the HW cylinder and the bottom of the CW tank.
Sorry.
Head is distance from the surface of water in a tank to the level of the outlet.
Plain and simple.
Look at it this way...
Q. What is the head at the outlet from a tank?
A. The depth of the water = surface to outlet distance.
Therefore wherever the outlet of a system is, the head is the distance from water surface to outlet. All the pipework in between only goes to reduce the head due to resistance to flow.
[snip]
This you have partly wrong but it maybe the way it's worded.
The distance from the water to the outlet (being the top of the cylinder) you cannot increase it from this point.
The head is not reduced through resistance, the volume will be.
The higher you raise the pipe from the outlet the lower the head will be.
Ignorance is curable but stupidity is a permanent condition so stick to playing with sparky things Matthew.![]()
thanks for the laugh though.![]()
Answer the two basin example then Matthew.
Two basins side by side, you connect one straight from the top of the cylinder, and you run the pipe into the loft and drop down to the other.
Which has the highest pressure.
this is going to run longer than word association![]()
Ok why does the pressure get less the higher you raise the shower rose.![]()
How long are you going to run with this same argument? You ask me to answer the 'two basin example', I answer it and make a valid point, although you don't like what you hear and completely ignore it. I might as well be banging my head against a brick wall, because every time I come up with a valid counter-argument, you just cite the above statement regarding pressure drop as the head becomes smaller.
Again, NOBODY disputes that less head (ooh-er) = less pressure, because it's true and we can clearly demonstrate that fact. What you seem to be doing is detracting attention away from your original claim that head is ONLY the distance between CWS and HW cylinder, and anything after that can (in your opinion) make no difference to the system head. You still haven't provided any evidence to prove this.
You agree then if you raise the shower rose in the air you get less pressure, Pressure = head so you are say you have less head the higher you raise the rose.
Whats the difference between raising the rose and running a pipe up the wall, NONE
By the same token the pressure in the bottom of the cylinder will be higher than the top.
And if you bother to read my post, instead of talking gibberish, you will see, I said the head is from the storage tank to the highest part of the system, in the basin example it would be the pipe in the loft.
You agree that raising the rose to the ceiling will reduce the pressure, yet you say if you hook the pipe over the joist and run the rose back to the bath level, you get the pressure back again.
What you can't understand is that once the pressure is lost by raising the pipe, it's gone for good.
I'm not sure if you're being deliberately thick or just don't understand![]()
Ok you agree the rose is an outlet, A copper pipe with a tap on the end is an outlet, a cylinder with a pipe in the top is an outlet, the copper pipe is no different to the flexible hose in a shower.
Your hose, bucket, siphon example is pathetic from a desperate man, you cannot siphon water from an open vent cylinder.
The pressure in the bottom will be higher than the top by the height on the cylinder, and of course it's relevant, because the head is less at the top.
So if I run the shower hose up to within 20cm of the tank and drop back down you would expect to regain full pressure![]()
It is not a closed system, it's open vented and a siphon will not work.
Once again you loose pressure by raising the rose higher, exactly the same as you loose pressure by running a pipe up to the loft, you cannot mysteriously get back what is lost, by dropping it down again.
