Situation is that after removing bathroom tiles I'm left with 1/2 half of wall has tile adhesive (mostly dot/dabbed, not spread) onto render other half painted.
The top half (painted) tiles came away cleanly, bottom half (render) impossible to chip off tile adhesive (takes render off wall).
Dont want to tile top to bottom with tiles (cost being a big issue).
The render half is sticking proud by up to 12mm in places.
My idea is to (after searching this forum) apply slurry to painted area and render wall level/skim.
My questions/thoughts
1. Will removing flaking paint, scour with wire brush and sparrow pick the walls provide sufficient key. (really cant use the angle grinder)
2. As stated the render half is up to 12mm proud in places, should I render painted 1/2 level with render first and then when dry render over whole wall?
3. Slurry mix, apply to whole wall or just painted? What mix and what sand? Should I let dry first before applying renderAlso in South Africa so can only use permobond which I believe is a PVA.
I did find this post, http://www.diynot.com/forums/viewtopic.php?t=181887, but it seemed to refer to skimming
Thanks for any help
Thanks for any help
