- Joined
- 9 Sep 2009
- Messages
- 1
- Reaction score
- 0
- Country
This question has been on my mind for quite sometime now. What can cause serious voltage to short coax. I have done cable for 4 years now and know a good deal more than most but, do not know the 1st thing about electricity. It started 4 months ago when I was unscrewing a coax line from the back of a cable modem and the wire fell on my arm. When it hit my arm it clinched up as if I had my fingre in a wall socket. I did not think too much of it and screwed it back in, it sparked, and the surge protector shut down the rest of the equipment. Told customer to call electrician. She called me back and said he stated our wires were not grounded but, they were. And even if they were not they still should not have had that much voltage running thought them.
Next incident I was cutting a line on a splitter outside and soon as I did it threw a breaker. Quit what I was doing and said call an electrician.
I this point I said its time to buy a voltage tester.
3rd incident- at the side of a house hooking up the service and check the homerun going into the home for voltage, bingo, my meter checks for a min of 50 volts, by the way. So I told the customer to unplug the TV's one by one until it ceased and it did. Easy fix here.
4th incident skip- not too relevant
5th incident (the whopper)- unscrewing a line off of a splitter going to a modem, soon as I unscrew it WHAM, I feel the juice pulsating through me I blackout for about 3 secs and wake up on the ground. Come to my senses and tell the home owner to go unplug all tvs vcrs etc from the power outlet incase something is backfeeding power into the line. Checked the line still a whoping amount of juice, my tester going crazy when I even put it close to the coax. Then proceed to tell them call and electrician.
Now, I am VERY curious what is causing this. Ideas, staple through romex and coax(unlikely) - rat chewing two shorted (HUMM) - power not grounded trying to find a ground, coax feeding through romex hole in wallfish stud shorting somewhere.
IDEAS PLEASE!!!!!!!!!!!!
