boiler running 24/7 potterton profile 50e
15 Sep 2009
London
i,ve noticed that my bathroom rad is hot all the time this is acting as a by-pass valve for my s plan system have checked programmer and both port valves and they seem ok could it be my boiler stat.
thanks wiskerman...
thanks kevplumb
but i have checked the valves the micro switches are working fine
thanks
if the system is running when the programmer is off
wheres it getting power from check the orange wire in wiring center
check the valves are actually moving
you say you have checked them
how :?:
if i take the face of the programmer off which removes the switched supply
the boiler & pump still comes on indicating that its being feed via the permanant supply .
thanks
It's a valve switch failure then. Change the valve motor head.
this is a new fault
the permanant feed is only at the boiler to keep the pump & fan going till the water temp goes down and shoudn't bring on the gas supply
