ceiling : paper / plaster / pollfila
14 Dec 2004
I've just removed blown vinyl from my lving room ceiling and can see why was there in the first place, it is quite rough and looks like a very thin layer of plaster was put on over the orignal plaster, this is now flaking off with the paper removal. What are my options: the room is approx 25m2, is it possible to put up lining paper that should cover all the sins, get a plaster (how much should it cost for a ceiling 25m2 approx); think that might be quite expensive, or go for polyfila textured ceiling paint?
I’d say plaster but then I’m biased; lining paper won’t hide it. All the flaking plaster will have to come off to provide a sound base whatever you do & by the time you’ve finished, you might as well get it completely re-skimmed properly than mess about with filler & sanding. If it’s in bad way, it’s sometimes easier & quicker to just overboard the original ceiling & skim that. For god’s sake don’t use textured ceiling paint!
As Richard says for gawds sake stay well clear of textured paint! As much as I prefer lining to skimming it does sound like in this case you're going to have to bite the bullet & re-skim :roll:
the price for skimming your ceiling.should be between £100-£150.on average.but depends on what area you live. simon the spread/builder
That's a bigish cieling to do for 100-150 quid! I would say more like £200 + materials; more if it needs re-boarding!
thanks for the info i must be a bit cheap.i know it varies a bit depending on where you live. simon the spread/builder
