Have done a little reading around choosing the right pump for my mira thermostatic mixer shower. I am happy with a salamander but unsure what size I should go for. Showering performance is very important to me and my partner so i don't want to get this wrong. I have a plumber coming tomorrow so please advise before then would be great.
Choice is between the RSP 50 (1.5bar) and RSP 75 (2.0 bar). I hope to fit on the floor by the hot tank which is at same level as bathroom up through to the loft and across and down into concealed pipework for mixer shower. There is about 3 metres between hot tank and shower (straight line of course). cold tank is in the loft.
I am used to the performance from a decent power shower and would like as close if not the same performance.
I measured my current flow rates - please be kind - I have little idea how to do this correctly (hoping I got it right). At the moment when I measure my flow from the shower head (mixing cold and hot) I get about 3L per minute. From the shower water outlet (don't know the proper language to describe - where water comes out when I unscrew the shower hose of) I get 6.5 L per min and cold on its own - 4.5 lpm - hot on its own 5.5 lpm.
Lastly I see the smaller pump uses 15mm connectors and the larger 22mm. Do I need to be using 15mm piping with the smaller and 22 with the larger or what are my options to maximise performance or does it matter. Some of my 15mm pipework is concealed behind the false wall for the shower. Even if someone suggests I use 22 mm for either or both pumps would I loose much performance by converting to 15mm just before I get to the concealed 15mm. don't fancy ripping a wall down to change all to 22mm.
So given all that to get a performance similar to what I'm used to (power shower) is the 1.5 bar enough?. Thanks ever so much for anyone who can help put me straight and at ease with choosing a way forward.
