Hi
I have a single 2 port valve above my Potterton boiler which from what I've read controls the flow of water to the rads. The valve seems to open and close correctly when CH is selected on the programmer BUT when CH is OFF and the valve is closed the outlet pipe to the rads is still hot and some of the rads still get hot, not very hot but still hot. If I turn CH on, either on the programmer or I open the valve manually with the little lever I can feel the outlet pipe get very hot so I guess open is working fine. If on turn CH off I can see the lever close but it seems somehow hot water is till getting through. Is it possible that the valve is faulty and is closing but not closing all the way thereby still letting water though? If so then do I need to replace the whole valve or just the actuator?
Thx
Richard
Thx
Richard
