Hello,
Noitced on our boiler last night that there is a green light flashing on the front panel,not sure if this should be flashing or not as with the panel closed we never get to see it.
We have also noticed that when we select a temperature on the wireless control unit in the hallway nothing happens,i mean normally we select say 20 degrees then the boiler kicks in and all is fine.What we have to do at the moment is select the desired temperature in the hallway then go upstairs and press the over ride button on the boiler then it will kick in and away we go.Radiators work fine & hot water etc is fine.
The needle in the gauge shows it is in the green area and reads about 1 1/2 on the gauge.
Please advise what i can do to rectify the flashing light and make connection with wireless control unit & boiler.
Not sure on what i need to do in regards of reset as the paperwork i have does not mention anything.Had this system fitted 2 years ago.
