we only found out tonight the fully spec of the system layout ie trv's etcTake the TRV heads off all the the problem rads and give then a squirt of wd40, and then lift the pin no more then 2-3mm.
Put the heads back on and enjoy the heat.![]()
Trying that as we speak and found something perhaps revealing? When I advance CH only on programmer, pump and boiler do not come on. Have had to advance HW too then pump and boiler come on. Lever on MV is floppy compared to stiffness when CH/HW off. Pipe downstream of MV is hot as is one of 2 main drop-pipes downstairs. Only one rad d/stairs appears to be warming up (slowly) and is the one nearest to drop-pipes. Normally rads warm up fairly quickly, if not rooms.
And the tap stat should still be on the return.
No disputing that, first time I saw the post was tonight and after 6 bottles of mexicos finest!
Honestly, don't think its as simple as stuck TRVs though...
i don't think its done on a c plan valve but s plan valve as i see before done that way
no not as an s plan system but using a 22mm 5 wire zone valve as aposed to a 28mm 6 wire valve as used on a c plan
