Help needed identifying flexi hoses
8 Mar 2006
London
Hello
I (kind of) know what I need but am looking for help from folks here to advise me whether such flexi's exist.
Bath mixer: I need a 2 flexi's - 1 monobloc end and the other end needs to screw on to a 22mm isolating ball valve.
Shower thermostatic mixer: 2 flexi's needed. 1 end to screw on to 22mm isolating ball valve. The other end needs to screw on a fitting that I don't know the name of! There's 2 of them that screw into the shower mixer - the 2 ends are offset so that you can position correctly I assume.
Do such flexi's exist.
Thanks in advance
what size their are two sizes for a monobloc tap.
Thanks in advance
i wouldn't use flexis on a shower mixer if its concealed.
Thanks in advance
The Bath mixer is a 10mm monobloc.
Yes, the shower plumbing is concealed. What would you recommed......coonecting the plumbing straight to the shower mixer with a compression joint?
Any idea what that fixing is that I don't know the name of?
Cheers
just use a section of copper pipe and join to your isolation valve.
yes connect with copper and compression fitting or m/f iron etc
have you a pic of the mixer your fitting ?
make/model.
make/model.
The link to the screwfix flexi is for 15mm, it's 22mm that I need.
Will do re shower.
