I have replaced an vented cylinder with and unvented cylinder and am having difficulty replacing the single cylinder thermostat wiring with a dual thermostat.
The original system is a Drayton Bi-Flo Control Packs. The original wiring from the LWC1 wiring centre was:
Terminal 14 Common went to C on the HTS3 thermostat
Terminal 15 Hot water on went to 1 on the HTS3 thermostat
Terminal 16 Earth on the HTS3 thermostat
I disconnected the above wires on the thermostat and linked as follows to the new dual aqua stat cylinder stat that was supplied with the Gledhill cylinder:
Terminal 14 Common went to Common on the overheat stat
Terminal 15 went to 1 on the control stat
Terminal 16 to earth on the dual aqua stat
Then took a link wire from 1 on the overheat stat to C on the control stat
Just kept blowing the fuse...
The instruction manual for the Drayton and the Gledhill unvented both say take the "Hot water on" to the common on the overheat stat. But the other side goes to the two port valve on one instruction manual and the programmer on the other instruction manual.
This is my first install having completed my Part P so need some help since first customer does not have heating or HW and it is getting cold...
Appreciate any help...
