replacing bricks mid wall?
16 Feb 2007
West Midlands
knocked some plaster off and found a bodge of half bricks and plaster filling in a hole that's ended up as about 4 bricks.. ( 1 over 2 over 1 ) to fill back in..
how do you do this?
how do I get mortar into the joints?
obviously I can get it on the top of the course below, but how at the sides and on top of the top brick?
There is an excellent post on here somewhere relating to replacing bricks in a wall, and how to get the compo in
fairly dry mix, on back of trowel line up with joint, push in with small trowel/bucket handle . For vertical joints ( perps) similar but make sausage in gloved hand ( to keep cement off skin) and because everyone wears latex gloves now :wink:
no point using a mortar gun then? expensive for what they are if it's only the one small patch I suppose?
I was considering a cake decorating bag ( icing bag ) to try and get it in.. would that do?
When you are putting the closer brick in, butter up the sides and top of the hole and angle it slightly. Butter up the brick and angle the mortar the other way. Push the brick gently in and then push in more if required with a tuck jointer if you have one, or a pointing trowel.
As this is inside you would drop a lump of mortar for the bed joint, butter the bricks and slide them in, and for any other open joints just flick a dollop of mortar in off the trowel.
It's not outside the Town Hall holding 50 storeys up, its a hole which is going to be plastered.
