I'll do the job right, so I'll bung in the vent, but what about the height of the expansion tank? I presume it needs to be a lot higher........but how much higher?
You can raise the F+E tank but the bottom of the F+E should be at the same level as, or preferably below, the bottom of the CWSC, so if raising it will put it above you should raise the CWSC also. Much better to go sealed if you can.
