Thermostat?
13 Dec 2009
Manchester
Hi
I have a biasi boiler and want to install a sunvic wireless thermostat. On the boiler I have a live and a neutral there is also a black wire in between and on the themostat I have SL(off) Lin SL(on) L and N. I have connected the L and N to the L and N on the boiler and thought that would be it but when the thermostat is connected the boiler does nothing. Where am I going wrong?? the boiler is valt free and so is the thermostat. Please help. :x
by the sounds of it link between SL off and SL on
remove link and connect to external time control/stat
unless you know better Dex :wink:
Maybe it's late and I'm getting confused, but I'd have gone for L and SL(on) to replace the link. Didn't think that SL(on) and SL(off) could ever meet to complete the circuit.
without digging oot MIs for boiler and stat
stat receiver has a live and neutral feed (could be from anywhere, flex and 3 pin plug)
stat receiver has a relay which is powered from the L,N
whatever the stats equivelant of C and NO is links to boiler C and NO outlet for external timeclock/stat
and with that....
goodnight gentlemen
CORRECT.
sorry Im still a know nothing to$$er
I am so stupid could you please explain in stupid terms. where does the live and neutral go. and should there be any links or anything.
Cheers
Just an update under the sticker it actually says NC, COM, NO, N and L. and I think these are the connections I need as it's volt free. please help.
Pity - it's too far (I'm in South Manchester).
Can you provide details of what specific sunvic model thermostat you have and also which boiler you have? Then (if noone else can advise), I'll search for diagrams and see if we can get somewhere towards a solution.
