how do i wire timer to boiler
10 Nov 2009
Cheshire
Hi guys,
i have a main combi 30HE. I have an analogue temperature thermostat that i use to switch the heatinf on the boiler on and off but this is no good no as i want to be able to set the boiler so it automatically switches on before i get up for work and switches off a few hours later.
anyway, i have a grasslin analogue timer FM/1 ST H. i want to install this on my boiler but unsure how to wire it up. The are 4 wires in total on the boiler to wire to the timer. 1 blue, 1 brown and 2 black which are connected to each other (i assume this is the switch wires)
anyway, there are 4 terminals that are on the timer numbered 1 to 4
can you tell me please what colour wire goes to which terminal. i would be very greatful
anyone help me please. im lost without your help.
cant find any instructions anywhere...........
Is there a small wiring diagram on the back of the timer?
Maybe:
1; COM
2; SAT/OFF
3; ON/CALL
4;
Or maybe in another order?
1 and 2 are always live and neutral 230v to power the timer I can't remember which way round but for functionality it doesn't make a difference. It is usually marked on the timer somewhere near the terminals or with a sticker
3 and 4 are switch wires low voltage
the timer is essentially joining the two black wires together
Not that it matters whats going on inside the switch but 3 is common and 4 is usually the switched live.
So you think:
N L 1 2 3 4
And 3 is common and 4 is call for heat.... are you sure :lol: ....
if you want to put built in timer in, wiring as follow
brown to no. 1
blue to no. 2
black to no. 3and no. 4
