View media item 18063 View media item 18064 View media item 18066 View media item 18068 View media item 18067 View media item 18065 View media item 18060 View media item 18061 View media item 18062
I have a pitched roof over the kitchen area which i've had to board out and felt over(due to low angle). I have yet to fit the tiles. There is no soffit, as joists end up nearly flush (or will be once rendered) with wall. I was then going to put pvcu fascia on the end joists then gutter it...I presume i need to vent the area beneath the boards to stop condensation/rot. In this situation what is my best option-to use Timloc vents as shown or can i just drill few holes through the fascia/wood noggins into the roof void? There is an inch or two gap directly above the concrete lintel-maybe i can use this to ventilate under roof boarding? Also there seems to be no way of venting the roof sides or is this unneccessary as will be rendered over?
Each joist is 150mm deep. I have bought 70mm celotex to insulate from inside. Do i fit flush with joist edge then fit plasterboard flush on top of this or will this leave no room for electrics/ceiling lights? Is it best to use vapour sheeting under the finished plasterboard? Thanks for any questions answered!
