    Dismiss Notice
Ventilation for cold flat roof
Discussion in 'Roofing and Guttering' started by Alex Buxton, 15 Nov 2019.
  1. Alex Buxton
    Alex Buxton
    15 Nov 2019
    5
    Thanks Received:
    Country:
    I am facing with the situation in converting part of my new garage into my office. I need to vent the 50mm gap above the ceiling insulation on a cold deck flat roof. I only know that during the last building regulation inspection.
    Roof is flat fibreglass so no over fascia vents like you would do with pitched roof.
    The fascia wood is screwed directly onto the end of the roof joists and there are no soffits to put a vent into .
    I dont really want to put mushroom vents on the roof as it will mean a lot of holes( between each of 10 joists) and look messy.
    what I really need is a louvered fascia board that is weatherproof but allows air in.
    Does such a thing exist or do I just fit a load of small louvres?
    Read more: https://www.diynot.com/diy/threads/venting-a-flat-roof.7063/#ixzz65NFV1v8p
  2. Sponsored Links
  3. Notch7
    Notch7
    15 Sep 2017
    20,007
    Thanks Received:
    1,400
    Sussex
    Country:
  4. Alex Buxton
    Alex Buxton
    15 Nov 2019
    5
    Thanks Received:
    Country:
  5. Notch7
    Notch7
    15 Sep 2017
    20,007
    Thanks Received:
    1,400
    Sussex
    Country:
    Sorry it should dont -edited.
    I mean downlighters in the ceiling.
    Im not sure about strong winds blowing water in, you have a point -I dont suppose your roof has gutter all round? -if so they could go just under.
  6. Alex Buxton
    Alex Buxton
    15 Nov 2019
    5
    Thanks Received:
    Country:
    on one side I have guttering, but not the opposing side.
    Does over fascia vents work for a flat roof (FibreGlass) ? Does it cost a lot more work to retrofit?
  7. ^woody^
    ^woody^
    3 Sep 2006
    30,058
    Thanks Received:
    3,917
    West Mids
    Country:
    You need through ventilation, not just on one side.
  8. Alex Buxton
    Alex Buxton
    15 Nov 2019
    5
    Thanks Received:
    Country:
    Hi woody, correct, both sides are needed.
    What would be the best option to do that retrospectively?
  9. Alex Buxton
    Alex Buxton
    15 Nov 2019
    5
    Thanks Received:
    Country:
  10. Sponsored Links
  11. noseall
    noseall
    2 Feb 2006
    39,527
    Thanks Received:
    2,503
    Staffordshire
    Country:
    Christ! Would it not be simpler you bite the bullet and have a warm roof?
  12. ^woody^
    ^woody^
    3 Sep 2006
    30,058
    Thanks Received:
    3,917
    West Mids
    Country:
    You will need soffit vents, or anything fitted in fascia risks letting rain through.
    You will also need to be sure that the air is ducted across the undeside of the deck not all over the place in the roof and wall cavity
  13. Notch7
    Notch7
    15 Sep 2017
    20,007
    Thanks Received:
    1,400
    Sussex
    Country:
    Yes thats the problem Ive found when trying to sort out incorrectly build cold roofs.
    Back in the good old days flat roofs were 8 x 2 joists and a bit glass fibre pushed up.....none of this new fangled ventilation stuff.
  14. ^woody^
    ^woody^
    3 Sep 2006
    30,058
    Thanks Received:
    3,917
    West Mids
    Country:
    Yes I often wonder whether this "ventilated cold roof condensation" malarky is actually made up, as I dont ever remember seeing roofs wrecked by lack of ventilation and as opposed to by some ongoing leak or felt failure.
  15. noseall
    noseall
    2 Feb 2006
    39,527
    Thanks Received:
    2,503
    Staffordshire
    Country:
    We have stripped a few. Oddly, the ones with the old wooden boards seemed ok. The ones with ply deck had a lot of black spot mould on the back of the ply. It may be that you could not see the mould on the back of the timber boards but I'm not convinced. One of the consequences of the mould is that when the property is empty and unheated for any length of time, there is an unmistakeable mouldy pong in the air, which could be attributed to the flattie.
    Other than mould nuisance, I'm not sure that there is any other detriment....:?:
  16. There was a publication called something like ' Thermal insulation and condensation, avoiding the risks ' published by BRE I think which gave the principles of vapour barriers/thermal insulation in different sorts of construction ,unfortunately I don't have a copy now .
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
