10mm Cable Going To A Fused Spur
5 Nov 2008
Many Thanks for all those who helped with this thread http://www.diynot.com/forums/viewtopic.php?t=206367
I will today do this job in my loft.
I will use the redundent 10mm cable to feed a fused spur and from the output side I will feed a double socket and another fused spur for the digital shower.
is this the correct fuse spur to use? http://www.keene.co.uk/electronics/multi.php?mycode=SWL1 or can I get a double sized one so that the 10mm cables go in easier?
Also at my wylex dual RCD consumer unit the 10mm cable is protected by a 40amp mcb - shall I also downgrade this mcb?
Happy New Year
If your spending all this money on spurs and sockets and a new mcb , why not buy a garage consumer unit which will allow you to terminate the 10mm cable with ease and will mean you have more capacity for any other future needs up there.. Search in screwfix for a garage consumer unit. you can then put two 16a mcbs in there and feed out to your socket and spur from it .
Nick
I see your point, screwfix do a consumer unit box with a main 60amp switch for £13 then the 16amp mcbs are only £5 each.
Will prob look a better job as well.
I think I would use a coffin JB next to the spur, and reduce the cable size accordingly.
If you were to buy that fused spur, be prepared to hunt for a security bit every time the fuse blows. Look at the fuseholder screw!
Colin C
