Our house has a split system (upstairs/downstairs heating can be on independently from each other)
I’ve recently had a replacement boiler installed and at the same time a new remote thermostat/timer was installed upstairs. Three weeks after the work was finished, the upstairs system has stopped working.
Under the hot water tank are three Honeywell 2 port valves (upstairs, downstairs and hot water)
The upstairs 2 port valve is failing to open automatically (can be done manually). In addition to that, the boiler is not being instructed to switch on. I can get heating upstairs if I manually open the valve, but this is only if the boiler is on at the same time (due to heating hot water or downstairs)
The radio receiver for the remote thermostat/timer is powered up, and an additional light comes on when there is a demand for heat.
Is the 2 port broken, or does it suggest an electrical problem.
Would a broken 2 port stop the boiler from switching on?
